blk92z34getrag Posted March 7, 2005 Report Posted March 7, 2005 Where the hell do I run it through? I can't find anywhere to run the amp power wire through the firewall... what have other people done? Will I have to drill a new hole? Quote
GP1138 Posted March 7, 2005 Report Posted March 7, 2005 Where the hell do I run it through? I can't find anywhere to run the amp power wire through the firewall... what have other people done? Will I have to drill a new hole? http://www.w-body.com/forum/viewtopic.php?t=21943 Quote
blk92z34getrag Posted March 7, 2005 Author Report Posted March 7, 2005 It's actually a large grommet covering up the hole where the clutch master cylinder mounts on the manual-equipped cars. You might want to run a drill bit through it first to punch a hole big enough to pass that big-ass wire through. I have a manual. I stated that in the title. I wouldn't have posted this because I already read that post if I had an automatic. Quote
GP1138 Posted March 7, 2005 Report Posted March 7, 2005 It's actually a large grommet covering up the hole where the clutch master cylinder mounts on the manual-equipped cars. You might want to run a drill bit through it first to punch a hole big enough to pass that big-ass wire through. I have a manual. I stated that in the title. I wouldn't have posted this because I already read that post if I had an automatic. There's a post right below yours in that thread that talks about drilling a hole right next to the hood release cable. I'd imagine that might work for you as well. Quote
z34_nut Posted March 7, 2005 Report Posted March 7, 2005 It's actually a large grommet covering up the hole where the clutch master cylinder mounts on the manual-equipped cars. You might want to run a drill bit through it first to punch a hole big enough to pass that big-ass wire through. I have a manual. I stated that in the title. I wouldn't have posted this because I already read that post if I had an automatic. There's a post right below yours in that thread that talks about drilling a hole right next to the hood release cable. I'd imagine that might work for you as well. i had drill a new hole in my firewall (where that punch out was), my grommet was completely differnt then every-one elses. Quote
blk92z34getrag Posted March 7, 2005 Author Report Posted March 7, 2005 Z34_nut could you post a picture if possible? Quote
