Need fast answer , fuel in oil and below zero temp outside
Thre the prob . my car sitted for 2 days outside ( and its like -25 celcius at night by here ) without a crank , nothing . Also , the car got so much fuel in oil ( due to the failed attempt to start it before ) that now in the garage since 2 hours , wont start at all . I started it saturday , after let it plugged for nealry 2 hours . What i am think is that they should flush the old oil who pretty bad and cold , to put some new oil in there , then start the car . it worked for me 2 days ago and the car ran for nearly 5 minutes ( beofre the serpentine belt tensioner failed ) i assume it can be the prob . What do you think ?
Gas in oil after sitting is usually leaky fuel injectors. If the gas got in there while it was running, the rings are bad.
with all the cranking your getting more gas in there and it just works its way down into the oil. Try putting the gas pedal to the floor and starting it, AFTER the oil change of course. This could also mean a bad fuel pressure regulator.
