removing the trans axle
im goin to pull the trans with the motor but how do i remove the axles from the trans???
:lol: ok so i wont break anything by just pull the engine out without the axles out. no bolts or clips?
No, you will break the axle shafts.
Disconnect the balljoints from the control arms, and yank the axles out of the transmission. They're not clipped in there or anything. Just pull hard.
don't do that.
just pull the brakes apart and get to the 4 bolts that hold the hubs in, yank them and you can pop the half shafts out. this way you don't have to replace balljoints or throw the alignment off.
