Jamz Posted February 28, 2005 Report Posted February 28, 2005 I first started my car with my remote starter , with ho problem the car started normally . But in the car , i noticed that the idle was fluctuating a lil bit more than usual , and after , i tried to put the car into reverse and back up , but the car stalled . I restarted it , put it into drive , and make it back to the sideway , but when i pressed the gas , thre was not much power , like i need to push the pedal really far to get the car go forward . I pop up the hood , and the engine was shaking more than usual . I put the Rpm to 1500 - 2000 during 15 seconds and the engine was doing well , but when i released the throttle , the engine stalled and i never got it back on . What the fuck could it be ? I boosted my friend car last night , but the car was doing well after that anyway . My amp meter is at 3/4 , and everything works fines besides that stalling thing . I got prestone , at normal level , i got heat , and gas . wth? the car is not bruning any prestone at all , and not loosing some too ... i cant understand . Quote
Jamz Posted February 28, 2005 Author Report Posted February 28, 2005 Just checked my prestone and oil , and there is no oil in prestone and vice verca . Quote
3.1LUMITIC Posted February 28, 2005 Report Posted February 28, 2005 hmm another 3.1 problem mine was doing the same thing try an idle relearn that helped mine for a while . Quote
Jamz Posted February 28, 2005 Author Report Posted February 28, 2005 idle relearn ? the car isnt even starting : | and thats a 3.4 DOHC . Thats not that . i just checked : fire , on one cylinder , and there is fire . dunno if i got to check for other cylinders due to the 3 coils . The car STARTED the first time and died , and now it wont restart . Quote
OldsmoBeast Posted March 1, 2005 Report Posted March 1, 2005 Could be a bunch of things. Check to make sure you don't have any loose vacuum lines anywhere under the hood. To me it sounds like that could be it. Might also be a clogged fuel filter, or bad plugs, wires, coils, or maybe even a sensor. Its very hard to tell. Start with the simple/easiest things and go one at a time from there. Sometimes its the most obvious thing but the last thing you'd expect. YK Quote
Bossman429 Posted March 1, 2005 Report Posted March 1, 2005 I would be checking the spark on all cylinders first. You might have a coil that is firing just one, or none at all, or a bad Ignition Control Module. Verify spark, once you know you have spark on any and all cylinders you can rule out the crank sensor, and Ignition Control Module. If you have full spark, I would then check fuel pressure, or at least make sure the pump is running. When you turn the key to run, you should hear the fuel pump wizzzzzzzzzzzzzzzzzzzzzz for about 2 seconds. If it's not, or you can't hear for sure, go pick up a fuel pressure guage. I'm not sure where the fuel pressure port is on a 3.4, probably on the fuel rail, I'd assume. Someone else can chime in if you can't find it, I haven't seen a 3.4 in about 2 years around here. (Not to start any of the previous arguements, but they probably ARE mostly in the J/Ys around here. ) EDIT: Oh yeah! Always check for spark before fuel. We started an Explorer on fire at work one time doing it the opposite way Didn't hurt anything, just burnt the fuel that was sprayed, and by then we got an extinguisher. Good luck. As expected, tell us what you find. Quote
Jamz Posted March 1, 2005 Author Report Posted March 1, 2005 Cool tnx Bossman429 , i started to look the same way than you told me . Tomorrow , i ll star and check fire on all cylinders . My idea is that : one coil is fried , so only 2 of them is workin makein the engine running on 4 cylinder , witch cause the shakin , and that loss of power i noticed . Then it stalled , because all the unburned fuel has been accumulated in the combustion chamber . Now , i ll check fire on all the cylinder , and i am sure at 85% that i ll foudn no spark on 2 of them . I hope this is only a coil , those things are easy to change . sorry if there is a typo or 2 cause i just drank some beer , to forget that my car isnt owrkin ... and for some other reason too damn btw , just owned a 1992 Mazda protege 5 speed and a 2002 Echo 5 speed with the 4 speed auto Mazda proitege 2000 . ( parents car ) 1.5 DOHC 105 hp of fury !!! Quote
Bossman429 Posted March 1, 2005 Report Posted March 1, 2005 I hope it's a coil too, because if that doesn't fix the miss, then it is probably the ever so expensive ICM. That's what happened on my 3.1. Quote
Jamz Posted March 1, 2005 Author Report Posted March 1, 2005 Wonder if the 3.1 ICM fits the 3.4 ? If so , i would kill myself to have not keep the one from my old 3.1 Quote
Jamz Posted March 1, 2005 Author Report Posted March 1, 2005 I got a Coil Pack from the junk yard . Tested , workin , 100 days warranty , 75 $ . And will have a ICM and 2 Coil spare . i will install them this pm Quote
Jcrow Posted March 1, 2005 Report Posted March 1, 2005 wait, you said you put in a remote starter? problem solved I don't know why, but it says in the GM upfitters manual that all warranties are void if a remote starter is installed. Quote
ShockTherapy Posted March 1, 2005 Report Posted March 1, 2005 might be the remote starter, but my guess is the ICM Quote
Crimson Fury Z Posted March 2, 2005 Report Posted March 2, 2005 as i found out, i need a new ICM and it will stall while idling or going slower than i'd say 20mph. autozone here has one for $80.99, vs a shop i had the car diagnosed, $165. Quote
Jamz Posted March 2, 2005 Author Report Posted March 2, 2005 Well i changed only the coil pack i suspected to be fried , to found that i need to change the ICM . Now that bitch is at a very very ( very ) bad place . do i need to remove the starter ? i just dont know it seems that there is 3 bolts keepin it there , am i right ? Quote
3.1LUMITIC Posted March 2, 2005 Report Posted March 2, 2005 no need to remove the starter. The only thing it thats its a tight squeez on the bottem bolt on the coil pack to the far left. when i done mine i loosend the bolt ontop of the started and moved that wire out of the way(you will see what one im talking about) and there ya go. Quote
GP1138 Posted March 2, 2005 Report Posted March 2, 2005 Just unhook the negative battery cable before you do this, because otherwise you'll be a moron like me and drop the ICM/coilpacks down on the starter terminals and a huge SNAPSPARK will scare the shit out of you. That had to happen to me at least 5 times in PA when working on the FrankenPrix with Chris. Quote
White93z34 Posted March 2, 2005 Report Posted March 2, 2005 all 60* coils and ICMs are interchangeable, and are the same except (and this is hearsay, i can't back it up) for the 3400, it supposedly delivers a hotter spark with its factory coils and icm. Quote
Guest TurboSedan Posted March 2, 2005 Report Posted March 2, 2005 not trying to sound like an asshole here at all so don't take this the wrong way! BUT - please try to be more descriptive with your subject titles. you WILL get more views and that = more help with your problems. i'm not singling Jamz out here but i am using this thread as an example. it will also help the search function become more useable. that being said, good luck with your problem Quote
Jamz Posted March 2, 2005 Author Report Posted March 2, 2005 yeah i know tnx for notice . I though about it , but i forgot . lol . Btw , they gave me a 1988 Berretta 2.8 ICM and one connector seems to dont fit ... well ill see that tomorrow , i ll try to get that bitch relocated . Quote
Jamz Posted March 2, 2005 Author Report Posted March 2, 2005 well going for another round today I will first : make my ICM wires Longer so i can test the other ICM without removing the first one . Then i ll change it . Quote
Jamz Posted March 3, 2005 Author Report Posted March 3, 2005 ICM replaced , i got fire to all cylinders , but engine will not start . WTH ??? I towed it to my mech , i ll check this out tomorrow . Tired of all this shit . He said taht this can be the timing belt , witch tajke 4.6 hours to do . That sucks . Or maybe the cylinders are so full of unburned fuel , that there is no compression and nothing happening . Will see tomorrow Quote
Jamz Posted March 3, 2005 Author Report Posted March 3, 2005 Ok now i got some probs . The Timing Belt is gone . Dunno why the coils and the belt failed at the same time , but i got no choice i got to fix it . The promblem is : The carnk turned , but not the cams , i need to re-time the engine . At the garage , they said that i need a special tools to retime the cams . Do i have another choice ? is there something to do to retime wihout this special tool ? thanks Quote
JoroCorona Posted March 3, 2005 Report Posted March 3, 2005 I would get it done professionally. I did mine and it was a bitch. Quote
