rshissler Posted February 28, 2005 Report Posted February 28, 2005 ok i finally got some time to pull the 2.8 out and work on it now my question is where the hell are the mountin bolts on the drivers side i can see where they are bolted to the engine but where on the frame is it bolted? and how do u remove the axles from the trans? do i have to remove the tires and such? Quote
mihela816 Posted February 28, 2005 Report Posted February 28, 2005 Note that one of the bolts in the back bolts in backwards. The mounts for the tranny are at a big rubber mount, you can't miss it. Also there is a support bracket on the passenger side. Quote
