Rushman04 Posted February 26, 2005 Report Posted February 26, 2005 hey, i have loved my grand prix from day one but i have run into a problem with the coolant. My motor is eating up coolant and its not a hose. My garge checked it out and they said it doesn't hold pressure. Its either the lower intake maniford gasket or a head gasket. The oil is not white so the oil doesn't seem to go into the oil. The performance of my car has gone down. Whats do you guys think? Quote
slick Posted February 26, 2005 Report Posted February 26, 2005 Lower intake manifold gasket. I can almost guarantee it. Quote
terryk2003 Posted February 26, 2005 Report Posted February 26, 2005 Lower intake manifold gasket. I can almost guarantee it. :withstupid: ...if you thought it was a head gasket you could prolly do a compression test on the cylinders...but, i'd put money on lower intake gasket... Quote
Givemebreak Posted February 26, 2005 Report Posted February 26, 2005 I think that is the case with my car too....can't find where its going....but there is a leak and it don't hold pressure....I believed the intake was leaking toooo..... So I will ask the next question....has anyone changed this gasket out? Quote
sl3196 Posted February 26, 2005 Report Posted February 26, 2005 So I will ask the next question....has anyone changed this gasket out? Who hasn't with a 3100? (I did in my old cutlass) Quote
slick Posted February 26, 2005 Report Posted February 26, 2005 Lower intake manifold gasket = not hard to do. Done it on my 3.4, should be fairly similar to the 3100. Quote
cutlsp Posted February 27, 2005 Report Posted February 27, 2005 i need to do this to my 2.8 the coolent is going somewhere but none of the hoses are leaking :? Quote
sonyman87 Posted February 27, 2005 Report Posted February 27, 2005 .. my coolant is going somewhere also and i know the intake gaskets are good. No cold starts even on the coldest of days. Its a very slow disappearance. I never really have high preasure in my coolant lines b/c of the low therm settings. just every other month i have to add a half a gallon of coolant Quote
3pt1lumina Posted February 28, 2005 Report Posted February 28, 2005 i'd bet money on lower intake manifold gasket... same thing happened to the 3100 in my malibu and my dad's 3100 in his lumina 2 times Quote
ShockTherapy Posted March 1, 2005 Report Posted March 1, 2005 it's been known to happen on just about every 3.X.... Quote
Rushman04 Posted March 2, 2005 Author Report Posted March 2, 2005 thanks for the advice and i will be replacing the gasket tomorrow and i will let everyone know if it was. Iam going with everyone is saying because the head gasket would be worst. Quote
Rushman04 Posted March 2, 2005 Author Report Posted March 2, 2005 :!: :!: :!: :!: :!: TROUBLE! Hey i got my car out today to go to school after letting it sit from yesterdays snow strom. The idle in the car is bad. It idles at 2 grand or if i stop at a light it will go down to less then 500. Is this because of the intake gasket? I cleaned out the throttle body when i came home and it still does it. The last time this happened it just needed a good cleaning. Quote
THe_DeTAiL3R Posted March 3, 2005 Report Posted March 3, 2005 Yep, if you got a leak somewhere on the intake side it can really fuck around with your idle. It can even throw an SES code. When I forgot to tighten the throttlebody (after changing the stat) air was getting in and it idled like crazy, ran real hot and throw and SES light came on. After tightening it back up it ran perfect after... Quote
slick Posted March 3, 2005 Report Posted March 3, 2005 :!: :!: :!: :!: :!: TROUBLE! Hey i got my car out today to go to school after letting it sit from yesterdays snow strom. The idle in the car is bad. It idles at 2 grand or if i stop at a light it will go down to less then 500. Is this because of the intake gasket? I cleaned out the throttle body when i came home and it still does it. The last time this happened it just needed a good cleaning. Yep, again, more signs of an intake gasket in need of repair. Quote
