more info on adjusting the throttle valve cable
i looked in chilton, and then on the car. I don't quite understand it. A how to would be great. THe problem is she isn't shifting into overdrive
THanks
Nick
You have an Electronicly shifted trans, so i would bet it has a bad solenoid, not the tv cable being misadjusted...if it shifted crappy in all gears, then i'd say mess with the tv cable
even though he has the "E" trans it still has a vacuum modulator and if the diaphram is wasted the tran can do some weird shit. Are you saying it is not going into 4th gear or the TCC is not engaging or "locking up"?
well i dont know which is which. No one ever really cleared it up. I would say it shifts 4 times, meaning 4th gear but it won't kick down that one last time while crusing on the freeway. thats the best i can e3xplain.
