LarryMartin830 Posted February 22, 2005 Report Posted February 22, 2005 dose any one know how to change a front speaker in a 93 Cutlass? and what size are they need to know ASAP plz Quote
GnatGoSplat Posted February 22, 2005 Report Posted February 22, 2005 4" in the dash, 4x6 in the doors if you have 'em. Have to remove the dash pad to get to the dash speakers. - Put the tilt wheel all the way down. - Remove all phillips bezel screws (along top edge) with a stubby screwdriver. - Remove bezel by pulling back (held in with clips along the bottom). - Remove 2 7mm screws on either side of the bottom of the opening. - Remove both inner and outer defroster vent by pulling out. - Remove 2 7mm screws in the defroster vent. - Remove 2 7mm screws in the glove compartment. - Remove dash pad by lifting up and back. Quote
GTPrix Posted February 22, 2005 Report Posted February 22, 2005 (what Shawn said). I've had my dashpad off many times and its quite easy. Are you upgrading your speakers? If so, I've got the component set I had in my car. Later Drew Quote
LarryMartin830 Posted February 24, 2005 Author Report Posted February 24, 2005 no i am just replaceing it its blown Quote
BimmerJr87 Posted February 24, 2005 Report Posted February 24, 2005 I have some 4" Kenwoods, that will fit with the wiring harness if you want to buy them! Quote
