Help, misfiring after engine wash and new plugs
Well yesterday I washed my engine off. I didn't cover anything but didn't spray directly on the coil packs or anything. Then I put in new plugs, didn't start the car in between the two. Used NGK TR6's gapped at .054-.055. Anti-siezed the plug threads and put dielectric grease in the plug boots. All the wires are routed correctly and on snug. Still using the stock 100k spark plug wires. They don't seem frayed on the outside.
Now the car idles fine, there is only a problem when moving under load/boost. Thinking it is bad wires or something got wet. Any ideas? TIA
sounds like it might be a bad wire...maybe caused by the dampness...also, make sure none of the wires got up against something they werent supposed to (something hott or metal) because they could be arcin out on something...
Guest TurboSedan
Dan, we should try pulling all of the spark plugs back out and recheck things. i bet one of the plugs will look different than the others, IOW a bad spark plug wire somewhere in there. it took ALOT of pulling/twisting to get the spark plug wires off of the 100,000 mile old plugs :!: so i think one wire may have gotten damaged in the process.
Yeah Josh that is part of the plan today. If they all look good and it still does it, I will put in the stock plugs to eliminate problems with the plugs. Going to get an ohm meter and check the wires and coils too. Think I'm going to order some new wires.
You haven't left for deadwood yet?
Yea when I do my plugs next week I bet it will be a disaster.
Damn thats Sick!!!! :shock: :thumbsup: :thumbsup: :thumbsup:
Is that turbosedans pressure washer? Anyway what kind of plugs did you get and did you feel a big differance with the new plugs in?
No wait I was just searching NAPA online for some spark plugs for my regal and I think I know what kind those are. NGK V-Power about a 1.79 a plug????
Nah it's my dad's carpet cleaning machine.
Did you read the post there hokem?
I'm having a similar problem, although it's probably something different then yours. Did you try to start the car after washing, or did you just do the plugs?
Didn't start it between the two.
Guest TurboSedan
Was a cracked plug. Runs great now!
:rocking:
did you find another NGK plug here in town? and did you end up replacing the wires too?
glad to see you got it fixed...was the plug messed up when you put it in!?...or did he get broke from installation!?...just curious...i know my dad had splitfire plugs in his '96 cutty when the first came out and he got a bad plug...the insulation was broke and was causing a miss & about 35mph...just kinda curious if your problem was similar (caused by defective part)...
:rocking:
No travis even called around at napa for me and nobody has them. Got some autolite 104's. BTW: It was the #6 plug by the o2 sensor. Remember that pop we heard when putting it in? :lol:
:rocking:
Why did it break? Too tight?
Yeah must have torqued it too hard. I didn't think I used that much force though. Might have just been a weak plug.
Guest TurboSedan
nah i think we were sort of tightening it at a wierd angle since the O2 sensor was directly behind it in the way. that one was kind of a pita.
Yeah that was probably it. It was a breeze doing them the second time. Didn't even have to rotate the engine this time.
