cold air intake system and Reading ECM info and code definit
Okay my first questions is what is a good cold air intake system for my car, and will this effect my computer at all?
My second question is about the info that you gave about Reading ECM info and code definitions (non OBD-II). I look at the ALDL connector and there is nothing in the B slot . There is a black wire wich leads to the A slot , orange wire to the M slot and a green wire in the I slot. I have a pic of it ,but I am unable to post for you guys to see? So when i use a paper clip and have the key in the on position what wire sould i connect with when using the black because the black is the ground right? If this doesn't work then what should I do?[/img] Thanks
Scott 95 Pontiac GP GTP
You can't (easily) check the codes on a 94-95. It's gm's bastardized OBD 1.5 system. You have to use a decent-quality (read $$$) scanner to get the codes.
As far as cold air intakes, they don't typically affect the computer. You may need to unhook the battery for 30-40 mins to reset the computer, but usually you don't have to.
