Ecm fuse?
Its in the engine bay around the general area of the Postive Aux. battery cale/terminal. I think there is a plastic cover that says ECM Fuse, you pop the cover off and it is just a standard sized fuse.
Pull the fuse, leave her off for a few seconds pop it back in. Start the car put it in drive and run for 5-7 mins. Shut down engine, restart and do the same thing - put in drive and run for 5-7mins. Shut down, idle is learned.
- Jeff L.
I'm pretty sure that little black box circled in green is where the fuse is located. At least it is on a my 1990 Lumina and it should be the same as the GP?
- Jeff L.
well in the flue panel int he glove box, theres also a fuse that says ECM under it, and in the ECM and Fuel pump thingy under tthe hood it has a fuse, are there 2?
To do a Idle relearn you can also just take off the battery cables and do it like that. :wink:
have you seen where the batterys are in the 3.1s? taking out the fuse is alot easier
The negative battery cable is easily accessible on a 3.1, just use a wrench and it takes a few seconds to remove.
- Jeff L.
I thought that was the fule pump relay? Anyways, yes there is an ECM 15 amp fuse in the fuseblock in the glovebox.
