Need your quick help (torq spec outter tierod plz)
Anyone with a chiltons?
car is up on stands and wheels off...forgot to look up the spec.
The bottom nut that has the cotter pin....whats the torq spec on it please?
TIA!!!!!
I've done a couple tie rods, I've always just tightened the bolt until I am able to slip the cotter pin in (which is fairly tight). Just don't losen the bolt after tightening it (something I read, probably Haynes manual).
here's what haynes says (im not sure if this is exactly what u want):
Tie-rod end nut: 63
Tie-rod jam nut: 50
thats all i could find, hope it helps
Thank you gentlemen......I ended up doing what CBad noted....I think its fine now.
Thanks to you's :wink:
