I have a frozen strut on the drivers side front so I need to replace them.
Does anyone know if in the 99 MC, can you replace the strut catridges while it is still in the vehicle? I know with some W-bodies you can do this but not sure about the MC Z34.
Thanks
Glock
Yep, on the front struts of the 95-99 Montes you replace only the cartridges just like the earlier W-Bodies...
Thank you for the response.
Do you know if you can use the GM10 tool or do I need to remove the strut from the car to replace the cartridge?
The replacement procedure is the same, and you do have to use the special tool. No need to remove the knuckle from the car...
