need pics/description of turbo coolant supply line...
Guest TurboSedan
does anyone have pics of the stock TGP turbo coolant supply lines?
i am turbocharging a '91 block. i've already transferred over the sandwich type oil cooler/filter adapter. i've also replaced the oil plug in the block and installed the 45' oil feed fitting from the TGP block. there was also a coolant plug in the '91 block near the coilpacks, so i removed that plug and installed the fitting from the TGP block.
i have the oil lines figured out, and the coolant return line, but can someone describe the coolant supply part? i think it stars at the top of the waterpump then goes down into the oil cooler/filter adapter thing. then it comes out of that & is Tee'd off to the block fitting (near the coilpacks) and the other to the turbocharger. does that sound right? pics would be great...
TIA
Guest TurboSedan
Dunno of any of those will help....
that first pic answered my question. thanks Dave!
