red95cutlass Posted February 9, 2005 Report Posted February 9, 2005 I picked up a 95 Cutlass Convertible and I want to upgrade the suspension, sway bars and struts. I am looking at the GM parts direct site and they are selling this: http://www.gmpartsdirect.com/results.cfm?singlepart=1&partnumber=pk12456148 Would anyone know if these kits will work with my 95 Cutlass Supreme? Quote
herb427sc Posted February 9, 2005 Report Posted February 9, 2005 You want the rear trailing arms from a 97 or newer Grand Prix. Quote
90TGP Posted February 9, 2005 Report Posted February 9, 2005 That kit won't work with your car. But you can pick up these parts from your local GM dealer that will fit your car. Stop by your local GM dealer and ask for a 98+ Buick K-Bar. It's a front strut tower brace. You'll have to drill two holes on each side of your front strut tower plates [they're black]. It's easy to do if you have a drill with a good bit. You can also use the same bar for the rear. I believe this is the parts number for it: Part# 12456148 About $20 give or take with taxes. You can also get the GM Performance Parts tubular rear trailing arms from your local GM dealer. They are for the newer W-Body's, but they will fit your car. They are MUCH stronger then the cheap factory stamp steal junk you have on right now. Part# 12498649. You'll need two of them. About $45 a peice with taxes. Quote
red95cutlass Posted February 9, 2005 Author Report Posted February 9, 2005 Thanks so much! i was just looking for the number for the trailing arms!! Quote
Psych0matt Posted February 9, 2005 Report Posted February 9, 2005 is there anything different (in relation to this post) in a 94? if not then I'll hafta refer back to this thread later... I wouldn't think so, but it never hurts to check. Quote
90TGP Posted February 9, 2005 Report Posted February 9, 2005 Everything mentioned above will work on a 94. Quote
Intlcutlass Posted February 9, 2005 Report Posted February 9, 2005 Everything mentioned above will work on a 94. Are you using that kit on a 94? :?: Quote
