Ramma2 Posted February 8, 2005 Report Posted February 8, 2005 I have a 1995 Olds cutlass Supreme, its the vin M 3100 motor so I belive that it does not have the evil o ring oil leak I read about. Anyways its leaking oil, lots. About 1.5 quarts per 3000 miles. I do not believe that it is the lower intake manifold gasket, I have already changed that. What should I suspect next? Oil pan or rear seal? Both of which I assume are a pita to change. And information is much appreciated. Car is running great at 171k miles, I don't want it to go away yet! Quote
Ramma2 Posted February 8, 2005 Author Report Posted February 8, 2005 I'm getting some info from this article: http://www.w-body.com/service/oil-pump-seal.html It doesn't have my motor listed. Quote
mfewtrail Posted February 8, 2005 Report Posted February 8, 2005 You still have the oil pump drive & o-ring, so an oil leak there IS possible. Quote
