dohc v6 Posted February 7, 2005 Report Posted February 7, 2005 i have c2 18 on my 94z and i am having a problem with them. the hub is .5in and i have a spacer on there now the ring the wheel company gave me is 73 by70 and it is only .4in so the wheel realy does not sit in the center part. can i get some made at a local machine shop for my special application or no Quote
GnatGoSplat Posted February 7, 2005 Report Posted February 7, 2005 If you know of a local machine shop, call them and ask. Our center bore is 70.3mm. It's ok to run without rings, but you have to torque the lugs in steps to make sure the wheel centers properly (30-60-90-100 is what I do). You also have to check and retorque them after a few hundred miles because they will loosen as they seat. I learned that lesson the hard way. Quote
dohc v6 Posted February 8, 2005 Author Report Posted February 8, 2005 ok i am having him make some for me they are 16.9 mm wide with a id of 70.3 and an od of 73.4 Quote
90TGP Posted February 8, 2005 Report Posted February 8, 2005 You might need longer wheel studs with that spacer. Quote
