thedeef Posted February 6, 2005 Report Share Posted February 6, 2005 anybody know if this is hard in a regular old 90 lumina 4-door? anybody have the instructions for such a task? deef Quote Link to comment Share on other sites More sharing options...
jeremy Posted February 6, 2005 Report Share Posted February 6, 2005 remove four bolts for each front seat and IIRC the rear is only 4 bolts too... try searching too. Quote Link to comment Share on other sites More sharing options...
Dannymik Posted February 6, 2005 Report Share Posted February 6, 2005 Im not going to be very descriptive about the procedure, but its very easy! I can even do it Quote Link to comment Share on other sites More sharing options...
J Posted February 6, 2005 Report Share Posted February 6, 2005 4 bolts in each seat, the front all together has 8, sort of a pain, but easy if u understand what i am sayin. Just be careful not to scratch your car taking them out, or the plastic b pillar cover. The rear has two on the bottom, u can't see them unless you kneel outside your car and sort of look up under. Then the rear bottom comes out. Then two bolts on the upper portion and then lift up and out. Easy as hell. Hope this helps Jay Quote Link to comment Share on other sites More sharing options...
thedeef Posted February 9, 2005 Author Report Share Posted February 9, 2005 so are we talking about a 30 minute job or a 2 hour job? thanks for the help BTW deef Quote Link to comment Share on other sites More sharing options...
jeremy Posted February 9, 2005 Report Share Posted February 9, 2005 15 minutes tops... Quote Link to comment Share on other sites More sharing options...
slick Posted February 9, 2005 Report Share Posted February 9, 2005 Front seats are 8mm. Rear seat, bottom cushion. There are two bolts, they are 1/2". The rear seat back cushion, there are either 2 or 4 bolts(GP had 4, Z34 has 2). They are 11mm. Quote Link to comment Share on other sites More sharing options...
Euro Posted February 9, 2005 Report Share Posted February 9, 2005 hmm good to know info!! ll come to this when i take my seats out to do the carpets in the spring time! Quote Link to comment Share on other sites More sharing options...
slick Posted February 9, 2005 Report Share Posted February 9, 2005 They are easy to pull out too. Also, the above info. is for bucket seats in the front. Never had a W-body with benches in the front, so I'm not totally positive if the above info. is correct. Quote Link to comment Share on other sites More sharing options...
Euro Posted February 9, 2005 Report Share Posted February 9, 2005 They are easy to pull out too. Also, the above info. is for bucket seats in the front. Never had a W-body with benches in the front, so I'm not totally positive if the above info. is correct. grrr damn the bucket seats.... Quote Link to comment Share on other sites More sharing options...
slick Posted February 9, 2005 Report Share Posted February 9, 2005 Truthfully, it shouldn't be all that hard to pull out the front bucket. Quote Link to comment Share on other sites More sharing options...
thedeef Posted February 9, 2005 Author Report Share Posted February 9, 2005 i have the 60/40 bench in my 90 lumina 4 door, but i'm sure it's not much more difficult than what you're describing for the buckets. all i need now is a place to do it...(college dorm parking lot is not working for me... deef Quote Link to comment Share on other sites More sharing options...
DiscoStudd Posted February 9, 2005 Report Share Posted February 9, 2005 The front split-bench has the same mounting brackets as the bucket seat does (the driver's side is the only one that's different, passenger side is a normal bucket seat.) At least it's that way on the 95-01 Luminas, but I'd assume it's the same on all the rest of the 4-door split-bench W-Bodies... Quote Link to comment Share on other sites More sharing options...
slick Posted February 9, 2005 Report Share Posted February 9, 2005 The front split-bench has the same mounting brackets as the bucket seat does (the driver's side is the only one that's different, passenger side is a normal bucket seat.) At least it's that way on the 95-01 Luminas, but I'd assume it's the same on all the rest of the 4-door split-bench W-Bodies... If thats the case that they share the same brackets, then they all should be the same. I know there was no difference between the mounting locations(except for the rear seat back bolts, there was 2 extra on the GP). Quote Link to comment Share on other sites More sharing options...
