stockgp Posted January 31, 2005 Report Share Posted January 31, 2005 well after screwing around with the wires most of the day i finally got all my signals and hazards to work properly. although, i didn't use 4 wires and the turn signalswork whether or not the ignition is on... thanks disco and justin. p.s.- if anyone happens to need a scan of a 93 gp c202 connector just ask. Quote Link to comment Share on other sites More sharing options...
Canada Posted January 31, 2005 Report Share Posted January 31, 2005 I'm looking at a 1998 Monte Carlo (I can't go any older...GM doesn't have anything newer online).........it doesn't have a connector 202. Maybe you have the wrong one connector? How many pins does it have? Quote Link to comment Share on other sites More sharing options...
stockgp Posted January 31, 2005 Author Report Share Posted January 31, 2005 that's her. it's the connector that all the wires from the steering column run to to connect to the dash harness Quote Link to comment Share on other sites More sharing options...
DiscoStudd Posted January 31, 2005 Report Share Posted January 31, 2005 Nice diagram! I have a pic you can use: Don't know if that'll help you any but it's from a 95 Regal (which should be the same as any 95-99 Monte...) Quote Link to comment Share on other sites More sharing options...
stockgp Posted January 31, 2005 Author Report Share Posted January 31, 2005 yeah that's what i need, but i need the functions of the wires and all that. thanks, though Quote Link to comment Share on other sites More sharing options...
Justin Posted February 1, 2005 Report Share Posted February 1, 2005 For '96 GP. Quote Link to comment Share on other sites More sharing options...
Robby1870 Posted February 1, 2005 Report Share Posted February 1, 2005 Yeah, I'd like the functions of all the wires for the turn signal switch part of that bulk connnector. Im going to try to by-pass the brake lights going through the turn signal switch when it warms up, if I can. Quote Link to comment Share on other sites More sharing options...
stockgp Posted February 1, 2005 Author Report Share Posted February 1, 2005 hey thanks justin. you're the man robby1870, this is from my 93 gp diagram Quote Link to comment Share on other sites More sharing options...
stockgp Posted February 1, 2005 Author Report Share Posted February 1, 2005 hey discostudd and justin. i'm confused now. the picture discostudd put up with the line pointing to the 13-pin blade conflicts with the pinouts on justin's scan. in justin's scan the a blade has 17 pins, and the one in disco's pic has 13 pins. disco, are you sure the blade you were referring to isn't for the windshield wipers? Quote Link to comment Share on other sites More sharing options...
stockgp Posted February 1, 2005 Author Report Share Posted February 1, 2005 and one more thing. i have a steering column from a 96 gp and one from a 97 cutlass. i'm not entirely sure which i'm using, but they both have the same wiring in the 17-pin blade neithre matches the pinouts in justin's scan. here's what both my columns have, tell me what you think: a1 - purple - matches chevy on justin's scan? a2 - lt. blue - matches scan a3 - dark blue - doesn't match at all a4 - yellow - matches scan a5 - dk. green - matches scan a6 - white - matches scan a7 - black - matches scan a8 - lt. green - matches scan a9 - tan - matches scan a10 - empty - matches scan a11 - orange - matches chevy on scan? a12 - pink - matches chevy on scan? a13 - dark blue - matches female side of c202 on scan? a14-a17 - all match Quote Link to comment Share on other sites More sharing options...
DiscoStudd Posted February 1, 2005 Report Share Posted February 1, 2005 I'm fairly certain that's the signal switch. It's been over a year since I've replaced it, so I could be wrong. I'll have my GP's column apart this weekend to fix a broken cancelling cam spring, so I'll be sure to double check then. I do have some more pics you can peruse, though: In this pic, you can see it in the background. It has the "marks" in Black Sharpie written on it. In this pic, you can see the wires running from the column to the harness: Quote Link to comment Share on other sites More sharing options...
stockgp Posted February 1, 2005 Author Report Share Posted February 1, 2005 i got it figured out. you see those wires that are melted together and have white tape around them in the background of the 2nd pic? those are the turn signal wires. actually now i have a different, more interesting problem. i re-pinned that whole connector according to the info here and what i got from the stealership with some good, and some bad results. the good is that my driver's side signals are working. the bad is that they work whether or not the ignition is on. also my p.s. rear signal isn't blinking at all. the flasher is cycling, but no lights from the back. i don't know how the hell i'm going to figure this one out. i'm tired and my hands and brain are cold, so i quit for tonight. any input is greatly appreciated though guys . and thanks again for your help so far disco and justin 8) oh and what does the white wire that says brake switch feed to turn signal switch do? is that the function that keeps the hazard signals from flashing when you hit the brakes? Quote Link to comment Share on other sites More sharing options...
