need part # for non-AC idler pulley 3.1MPFI
My roomate says there was a threaded hole on the block on his 2.8 for it....I don't see why yours should be different.
Really!!
I've got a service manual to a 1991 Beretta.....................and for the life of me I cannot find the torque spec for the idler.
It appears to be a 15 mm headed bolt from the pictures. So. I would use the torque spec for the rear bolts of the compressor...........36 lb-ft.
......or you could use the torque spec for the tensioner bolt.
Which is 40 lb-ft. Both are the same diameter bolts.
Its your call. ;)
Guest TurboSedan
i'll post some more pics tomarrow....
i'm a little late with the pics, but here is the idler pulley installed:
mounting hole in timing cover:
thanks again for the help Canada :)
Guest TurboSedan
Nice... so is there a certain belt PN for this, or do we have to measure it ourselves?
i used part NAPA part# 060615 and it fits great (that's for the 3.1 MPFI of course). i asked for a belt for an '88 Corsica with a 2.8 V6 and no AC.
An FYI, the HELP! line makes bypass kits for AC deletion as well, I was looking through a pamphlet today at work and saw them. Just another route people can take I guess.
so the LQ1 does not have this mounting hole?
i'll have to check next time i'm at work.
