pbj59 Posted January 28, 2005 Report Posted January 28, 2005 Just had to pay $322.00 to have the reg. replaced on 93 GP SE, does that sound about right? They also replaced the distributer o-ring. The car was surging and wouldnt idle fo more than a minute. I guess it was just pouring the fuel in . Quote
Intlcutlass Posted January 28, 2005 Report Posted January 28, 2005 When mine went, I made atrip to the boneyard.... Freebie!!!! Took about 20 min to change...... The o ring.... couple of bucks in parts......another 10-20 min.... Quote
Justin Posted January 28, 2005 Report Posted January 28, 2005 I know the regulators are very expensive, I've heard like $150. Plus the time to remove the upper plenum and rails and I'd say you got off pretty good. Quote
Intlcutlass Posted January 28, 2005 Report Posted January 28, 2005 I know the regulators are very expensive, I've heard like $150. Plus the time to remove the upper plenum and rails and I'd say you got off pretty good. I didn't mean to sound like you got screwed in any way... When I read what I wrote, I felt bad... Anyway... You don't (or at least I didn't) have to take the rails off. There is JUST enough play so that you could replace the regulator without take'n the rails off. Quote
3.1LUMITIC Posted January 28, 2005 Report Posted January 28, 2005 Hey pbj59 what was your car doing b/4 you replaced the regulator b/c im having the same problem with surging off the line an crusing at 65 push on the gas alil an rpms droping an bucking up an down the rpms and high rmps at start up 2-3000 rpm idel until i put it in gear thanks Quote
