3.4 DOHC intake manifold
2-8 hp. Not worth the time, money or effort unless you do the heads & have the manifolds extrude honed as well.
I'f you're going to even try to port an intake, get a 96 manifold. The intake ports are bigger.
just wait till ben gets things situated and begins work on a NEW! intake manifold for the 3.4 :shock: i likey likey
im thinking of getting a intake from a 96 and porting that and putting it on my 92 sorry that i didnt tell you i also plan on getting head work done this summer
Well, if you're doing other work to the intake/exhaust path, you might as well get it done, it can't hurt anything but your bank account.
It's like pulling the diff in a rwd vehicle to swap it out for an LSD...if you're gonna do it, you might as well upgrade the ring & pinion gears as well to something numerically higher to take advantage of the extra traction available with the LSD.
