question about ffp coilovers
do the ffp coilovers w/ struts work with the 95+ brake conversion? i wanna do the brake switch, but i also want the coilovers.(im planning on lowering and using dimpled/slotted EBC rotors, and carbon pads). thanks for the help.
So you're saying you've got drums in the rear? Yeah, even though I don't have them, FFP has expressed that their coil-overs fit with drum or disc brakes (stock: I got on all four). The biggest concern about bigger brakes is wheel diameter and making sure the installation is complete and properly blead. I have a friend who crashed his car since his brakes fail after doing some 'home' conversions...
- RedFox340
Guest Anonymous
His car is a Lumina. It already has disc in the rear. He wants to upgrade to the '94+ disc which are better.
Yes the coil-overs should work with no problems.
