rshissler Posted January 26, 2005 Report Posted January 26, 2005 I was think of ways to make the car lighter and i thought of making fiberglass body panels for the car. Like the fenders bumpers back panels. Would this be like really dumb or would it work? anyone try it or does a cpmpany aready make fiderglass parts for our cars? Quote
Intlcutlass Posted January 26, 2005 Report Posted January 26, 2005 Not sure it would be worth the effort in making em. You could save weight by cutting the fat elsewhere.... Quote
Dirty Rockstar Posted January 26, 2005 Report Posted January 26, 2005 It would be a marginal difference in weight at that.. THese cars are just born heavy.. If you want a car to lighten up, grab an NBody FWD.. They're light and can be made even lighter w/ the huge aftermarket for them (Esp. Grand AMs..) Quote
rshissler Posted January 26, 2005 Author Report Posted January 26, 2005 ok i was just lookin to drop a few pounds on the car make it abit faster. Quote
maybe2fast Posted January 26, 2005 Report Posted January 26, 2005 alot of times in cars the back seats can be removed to shead some weight but the back seats in these cars are super light (not worth it) Quote
Tru2Chevy Posted January 26, 2005 Report Posted January 26, 2005 If you were going to have cutom panels made, why would you waste your time with fiberglass? Go straight to carbon fiber. There isn't much of a price difference if you are getting them custom made. 2fast....why would taking the backseats out not be worth it? They aren't very hard to remove, and every little bit helps. Better times, more mileage - Justin Quote
Intlcutlass Posted January 26, 2005 Report Posted January 26, 2005 If you were going to have cutom panels made, why would you waste your time with fiberglass? Go straight to carbon fiber. - Justin Glass you can do in your garage.... fiber.. I think is a little more complex, and I am positive is more expensive. If your just doing it to make your car faster... Don't bother with cutting weight. Add HP...... a lot of it. :devil: Quote
maybe2fast Posted January 26, 2005 Report Posted January 26, 2005 the bottom half of the back seat weights like 3 pounds... hardly worth the removal with the sacrafice of 4 seats. if it weights like 30 lbs then I could see taking the seat out. Quote
1990lumina Posted January 26, 2005 Report Posted January 26, 2005 2fast....why would taking the backseats out not be worth it? They aren't very hard to remove, and every little bit helps. Better times, more mileage All I think he meant, since I've had the back seat out of my Lumina laos, is that all pieces and cushions and stuff combined, it only weighes what I'm guessing like 10lbs maybe, maybe a little more, but not much. I do agree with you at every bit helps though -Jeff L. Quote
rshissler Posted January 26, 2005 Author Report Posted January 26, 2005 I was gonna do the work myself... Quote
Schudini Posted January 27, 2005 Report Posted January 27, 2005 I was gonna do the work myself... Dude, go for it!!! However, I suggest that you look into carbon fiber. A little more $, but stronger if done right. Quote
Intlcutlass Posted January 27, 2005 Report Posted January 27, 2005 I was gonna do the work myself... Dude, go for it!!! However, I suggest that you look into carbon fiber. A little more $, but stronger if done right. Fiberglass is also stronger than steel (if done right). It takes 4 to 5 layups of glass to match the strength of body panel steel. My rockerpanels were completely rotted. Rather than replace with steel that could rot again,I cut out the rot, then I coated all the areas I could with POR 15, and used a Zinc spray for all the hard to reach areas. Painted over that then glassed. My rockers are now mad up of 5-7 layers of glass. I did a little more because I had to drill back into them to screw in the studs that hold the ground effects brackets in place. I am proud to say that my 16 year old car if probably 98% rust free. And thats a daily driving car in one of the worst snow belt areas of the country. Can we say "salt spray". I hope to get the body all fixed up by end of summer. Sorry to Hijack, but i felt my recent experience working with fiberglass was relevant. Quote
rshissler Posted January 27, 2005 Author Report Posted January 27, 2005 ill give it a try this summer befor e i repaint the car... Quote
Intlcutlass Posted January 27, 2005 Report Posted January 27, 2005 Look What I just found: http://www.dickmillerracing.com/Fiberglass_page.htm Scroll to 1/3 of the way down... 1973-1997 Cutlass Heavy Duty Parts DMR FCTH-91 HOOD DOM 3 88-91 DMR FCTH-890 HOOD DOM 3 92-96 1973-1997 Cutlass Light Weight Parts DMR CTH-91 HOOD DOM 3 88-91 DMR CTH-96 HOOD DOM 3 92-96 Quote
GnatGoSplat Posted January 27, 2005 Report Posted January 27, 2005 Isn't the same size of fiberglass heavier than sheetmetal? I have a fiberglass spoiler and that sucker weights quite a bit. If you really want to lose some weight, get a smaller car! W-bodies are actually rather light weight for their size. Most cars in this size class are around 3800 lbs. I don't know about you personally, but I've seen pics of a lot of forum members and I think the greatest weight reduction can be obtained by changing to a lower calorie diet. Actually I agree with Intlcutlass the best idea is to add HP. Quote
Carotop Posted January 28, 2005 Report Posted January 28, 2005 http://www.usbody.com They have a fiberglass hood for cutlasses Quote
