rshissler Posted January 10, 2005 Report Share Posted January 10, 2005 Ok i got the part on gettin the code with the check engine light and when i do it the fans turn on and i keep gettin code 12? and i looked it up on here on the main page and im just confused can anyone explain the code thing like how long they will flash and if there is a promblem that i keep gettin code 12 over and over again Quote Link to comment Share on other sites More sharing options...
slick Posted January 10, 2005 Report Share Posted January 10, 2005 Code 12 means your in diagnostic mode. Quote Link to comment Share on other sites More sharing options...
skiiirt Posted January 10, 2005 Report Share Posted January 10, 2005 it will flash 12,12,12 then it will flash your error code so 12,12,12,32,32,32,12,12,12,13,13,13,12,12,12 that would be an error 32 and an error 13 Quote Link to comment Share on other sites More sharing options...
Robby1870 Posted January 10, 2005 Report Share Posted January 10, 2005 If you keep getting 12, then nothing is wrong Quote Link to comment Share on other sites More sharing options...
DiscoStudd Posted January 11, 2005 Report Share Posted January 11, 2005 it will flash 12,12,12 then it will flash your error codeso 12,12,12,32,32,32,12,12,12,13,13,13,12,12,12 that would be an error 32 and an error 13 It doesn't flash the code 12 after every code stored. It only flashes it at the beginning and the end of all codes. For example, if a code 32 and 13 were stored:12, 12, 12 13, 13, 13 32, 32, 32 12, 12, 12 It lists the codes in sequential order, so a 13 would flash before a 32. The cooling fans are supposed to run when you jumper terminals A and B on the ALDL (thus entering "diagnostic" mode.) Quote Link to comment Share on other sites More sharing options...
