rockyrunner99 Posted January 10, 2005 Report Posted January 10, 2005 how hard is it to remove the oil pan? i see there is a spot on the passanger side where the frame runs under the oil pan, is there a way to get to that. It is on a 90 GP with a 3.1, thanks Quote
Canada Posted January 10, 2005 Report Posted January 10, 2005 Your 1990 3.1 should be similar my 1991 3.4.....you have to drop the cradle a few inches to get the pan actually off the car. I didn't pull mine off for an oil leak, rather I had troubles with my crank sensor...it kinda broke. Quote
