Will the RPM guage work when switching from a Base cluster?
Can the Odometer be reset to the car's actual mileage?
Is a junkyard a good place to find one?
The Tacho needs to be run from the orange ALDL connector.. THen it will work
The ODO CAN be reset, but is very difficult and pointless..
The Salvage yard is the best place to look for one..
A note: you will need to repin your harness plug.. This thing isnbt just plug and play.. Good luck!
steve, you are the master of "getting this thing that was designed for a different year/generation/brand/style/make/model to work"
