rshissler Posted January 6, 2005 Report Posted January 6, 2005 the e-brake on my car doesn't work for some odd reason. its one of those that u have to pump to set (dont know if every 2-body was that) but it wont grab. i mean i pump it twice and it gets really hard i mean i can stand on the thing and it wont go no more and then i can just drive with no problem at all. I checked and none of the lines are broke and it dont seem like the lines are at all tenets. Any ever have this problem? Quote
DOHCRagtopguy Posted January 6, 2005 Report Posted January 6, 2005 Bet your rear calipers are kind of stiff. Time to pull the rear wheels and see if you can grease up those slider pins. Same thing happened to my old lady's 92 Lumina after we first got it. Turned out the calipers were locked up and would not work at all. The front brakes were the only ones working. Replaced both rear calipers and all was cool. Typical W-body bullshit brake system problem. Quote
CuttySup Posted January 6, 2005 Report Posted January 6, 2005 Yes, a common problem. GM trying to be revolutionary and not engineering a rear disc setup properly. Why do you think Chevrolet returned to rear drums with the 2nd gen Lumina? Quote
LukeZ34 Posted January 6, 2005 Report Posted January 6, 2005 I thought they used the drum setup for the 95 year? That's the only year I have ever seen a rear drum brake setup on a w-body. Quote
DiscoStudd Posted January 6, 2005 Report Posted January 6, 2005 Rear drums were standard on the 95-01 Luminas, discs were optional starting in 96. ABS was also an option during those years, not standard equipment... Quote
Crimson Fury Z Posted January 6, 2005 Report Posted January 6, 2005 my e-brake is broke, see if the cable is hanging from under the car.......mine rusted from the rear pass. caliper Quote
CuttySup Posted January 6, 2005 Report Posted January 6, 2005 Rear drums were standard on the 95-01 Luminas, discs were optional starting in 96. ABS was also an option during those years, not standard equipment...Did they even make Luminas in 2001? I thought the Impala took over for 2000? Quote
Regal_GS_1989 Posted January 6, 2005 Report Posted January 6, 2005 IIRC, the 2001 lumina was a fleet only vehicle (Police, taxi)etc. Quote
EurosportZ34 Posted January 6, 2005 Report Posted January 6, 2005 i think everybodys e-brakes on here either broke at some point or just plain don't work like in both of my Lumis Quote
Dannymik Posted January 7, 2005 Report Posted January 7, 2005 you can bet that they are frozen. When this happened to me I bought new ebrake cables and installed them. Then I bought a new hardware kit for my rear calipers and used never-seize on the slider pins. I needed my ebrakes for an inspection and therfore I fixed them. Junkie brakes even came on my '95 Cutlass which were suppose to be better then the earlier wbodys...they still were a POS! Quote
rshissler Posted January 7, 2005 Author Report Posted January 7, 2005 How do i go about breakin them loose? Quote
Dannymik Posted January 7, 2005 Report Posted January 7, 2005 How do i go about breakin them loose? I dont have the answer to that question...sadly I got them to break loose "after" I took the ceased up cables off of the car by pulling and twisting on them. Quote
DiscoStudd Posted January 7, 2005 Report Posted January 7, 2005 Did they even make Luminas in 2001? I thought the Impala took over for 2000?Luminas were made until the 01 model year, and in 2000 and 2001 they were only sold to rental fleets. So if you see an 01 Lumina on the market, chances are that it was a rental car... Quote
