Invasion1
well since not alot of air even moves threw those i went with a cheep apc one from autozone for the back and later did the front one with an orileys noname brand.. preety cheep
Your breather beats mine, as a temp solution I just took a 2" by 2" chunk of foam and zip tied it over a broken off chunk of the factory hose that went to the old airbox. Ghet-to. Good to know a 1/2 will fit in there, I need to pick one up.
As long as the factory PCV system on the back valve cover is kept intact it should be ok. I assume most people are changing the front one because of an aftermarket intake.
Yeah, I sort of completely forgot about the rear PCV. I guess it should be fine. Here's a picture of mine:
the front and rear pcv lines connect to the same line that goes into your intake.. i dont see how it would be fine if you just did one.. :shrug:
Not on a 2.8 or 3.1, and I could have sworn my '91 3.4 didn't either, there's only one hard plastic line going to the rubber intake hose.
