JDsCutlass Posted January 3, 2005 Report Posted January 3, 2005 First off, let me say "Hello", or "Howdy", depending on where you are from. I am new here, but not to the W-Body. I am a member of 60deg., but since that site deals with more than just W-Bodies, I figured this to be the place to go. Here is the question...1994 Cutty Supreme SL, DOHC, is the car. I have a persistent, door lock noise. Sounds like the locks are oscillating, (Chattering). VERY ANNOYING!! I thought I had it fixed. In front of the hood release lever, under the carpet, is a small relay that clicks when the "chatter" goes on. I replaced it, noise came back after 4 months. Doesn't do it all the time, seems more, when damp outside. Keyless works fine. I figure something is causing the relay to die prematurely. Any ideas? I know that someone else has had this problem. Thanx in advance. J.D. Quote
Guest Anonymous Posted January 3, 2005 Report Posted January 3, 2005 Factory or aftermarket keyless entry? Quote
JDsCutlass Posted January 3, 2005 Author Report Posted January 3, 2005 Factory. Car is...uh stock. For the most part. Quote
