ThunderBat Posted December 31, 2004 Report Share Posted December 31, 2004 hey guys,...I realize I'm slightly outside of our area with this one but I need a little help...my wife's 87 cutty ciera wagon has a turn signal malfunction...all the bulbs are working and the lights get brighter when you move the signal lever but they wont flash...so I'm guessing the flasher is bad...the problem is I cant find the bloody thing...I know a few of you guys also own Z24s and the like and I think they are in the same family as the ciera, so I was hoping someone here would have the info I need...there are two small silver items in the fuse panel inside the glove box, but there is no diagram to say what they are...there is no junction box under the hood that I can see...if anyone here has had a similar problem any help would be appreciated. thanx in advance guys. Quote Link to comment Share on other sites More sharing options...
supreme_style21 Posted December 31, 2004 Report Share Posted December 31, 2004 It should be at the base of the steering column.. just a few inches from it, near the firewall.. round silver canister. Quote Link to comment Share on other sites More sharing options...
White93z34 Posted December 31, 2004 Report Share Posted December 31, 2004 cutlass ciera is an a body, cavvys are j bodys in a ciera it ought to be on the passenger side of the dash, up around the glovebox area, when i changed mine in my old ciera i found it easiest to pull the glovebox out. Quote Link to comment Share on other sites More sharing options...
supreme_style21 Posted December 31, 2004 Report Share Posted December 31, 2004 cutlass ciera is an a body, cavvys are j bodys in a ciera it ought to be on the passenger side of the dash, up around the glovebox area, when i changed mine in my old ciera i found it easiest to pull the glovebox out. They put them way over there, huh. Now that you mention it, I remember tracking one down in that area on a Ciera at work. Quote Link to comment Share on other sites More sharing options...
ThunderBat Posted December 31, 2004 Author Report Share Posted December 31, 2004 I pulled the underdash insulator panel out and there was a flasher dangling by two wires...I turned the emergency flashers on and I can hear the clicking sound coming from behind the glove box as was mentioned...the flasher I was holding wasnt doing anything that I could tell...the autozone website said the replacement is $2.39, so I think I'll try this one and see if it does the trick...boy I sure am glad someone deciced to localize all this crap on the later models! Quote Link to comment Share on other sites More sharing options...
jeremy Posted December 31, 2004 Report Share Posted December 31, 2004 sounds like a stalk problem, not a flasher issue Quote Link to comment Share on other sites More sharing options...
