GPdriver1986 Posted December 30, 2004 Report Posted December 30, 2004 Ok, I found out the water that goes onto the cowl goes, inside and back out through the AC drain, Davis told me this on a past post. I'm guessing this is a problem with my water leak into the car. I finally got a look at the drainage today since it was above freezing, I took a 500 ml bottle and filled it with water, then i poured it on the cowl area (to see if it would drain from AC drain, it didn't) . Only the part right above the brake booster. It seems the water just poured out by the drivers side front wheel. Did some of did still go in the interior? Quote
GPdriver1986 Posted January 1, 2005 Author Report Posted January 1, 2005 Well i haven't checked if the water actually went into the cabin ( only the drivers floor pan is wet), I'm just trying to verify if did still actually still go through the HVAC because i did not see any water coming out of the drain and right now i'm assumption is that it is either plugged or the water does not go there. Quote
