rshissler Posted December 30, 2004 Report Posted December 30, 2004 This is kinda dumb but its not as easy as u think. How the hell do u get the seats out of a 88 regal. Theres like no bolts any where holdin the seat down that i can find. Can anyone help Quote
DiscoStudd Posted December 30, 2004 Report Posted December 30, 2004 Remove all of the plastic trim plates from around the base of the seat front and back. Slide the seat all the way to the back and you'll see 2 bolts holding in the front of the "sliders." Now slide the seat all the way forward and you'll see the 2 in back. The bolts have a "torx" style head on them, but a standard 6 or 12 point socket will get them out... Quote
rshissler Posted December 30, 2004 Author Report Posted December 30, 2004 So thats what those funky lookin things are. i see. Its rather a tight spot to get them out tho cuz there down inbetween the rails. Haynes Manual just said look fo rthe botls nothing about the style bolts. Quote
jeremy Posted December 30, 2004 Report Posted December 30, 2004 So thats what those funky lookin things are. i see. Its rather a tight spot to get them out tho cuz there down inbetween the rails. Haynes Manual just said look fo rthe botls nothing about the style bolts. like he said, just use a normal socket, they will come right out.... Quote
88Regal Limited Posted December 30, 2004 Report Posted December 30, 2004 Exactly. Just dont dostroy the covers and vaccume under there while the seat is out. You dont know whats under there..... Quote
Carotop Posted December 30, 2004 Report Posted December 30, 2004 When I put my leather seats in I found some nasty old food from my brother under there. And I found a bunch of change!! 8) Hey anyone wanna help me wire this seat up? Quote
jeremy Posted December 30, 2004 Report Posted December 30, 2004 Hey anyone wanna help me wire this seat up? wiring is normally plug and play... Quote
Carotop Posted December 30, 2004 Report Posted December 30, 2004 Mine originally didn't have power seats. Could I hook it up to the buckle up light circuit that goes on the seat belt? Quote
DiscoStudd Posted December 31, 2004 Report Posted December 31, 2004 Mine originally didn't have power seats. Could I hook it up to the buckle up light circuit that goes on the seat belt?No, that wire grounds out to the chime module and instrument cluster when you fasten your belt. A Hayne's manual should have the wiring diagram, if not hit up your local public library. Quote
Carotop Posted December 31, 2004 Report Posted December 31, 2004 You wanna meet up and try and wire it Disco??? Quote
DiscoStudd Posted January 2, 2005 Report Posted January 2, 2005 You wanna meet up and try and wire it Disco???Do you have a garage? Quote
THe_DeTAiL3R Posted January 2, 2005 Report Posted January 2, 2005 I put the power seats from my 88' into my 95 which didn't come equipped with any wires. I did however have all the wireing from the 88' which made it easy. For the ground I just used one of the bolts the seat bolts to.. For power I tapped into the power wire that goes to my amp in the trunk. :oops: (it was the closest power wire I could find and hasn't caused any problems). Quote
Carotop Posted January 2, 2005 Report Posted January 2, 2005 I gotta pull the seat out again anyway to get it wired so don't worry about it. I'll figure it out. yea and I think theres a cut in the carpet where I could wire it. Quote
Broan Posted January 2, 2005 Report Posted January 2, 2005 I think I tapped the power lock or window circuit, since none is continuous use Quote
Trep Posted January 3, 2005 Report Posted January 3, 2005 Haynes blows, get a Chilton. those are good, but I find the factory service manuals to be more useful. Quote
