stockgp Posted December 29, 2004 Report Share Posted December 29, 2004 does anyone know the difference between 93 and 97 headlight switches. the 93ish switches, from what i can tell are 4-wire. the 97 switch seems to only have 3 wires. how does it control the high beams and how would i make it work with a 93 headlight system Quote Link to comment Share on other sites More sharing options...
GutlessSupreme Posted December 30, 2004 Report Share Posted December 30, 2004 er... aren't the whole steering columns different? Quote Link to comment Share on other sites More sharing options...
DiscoStudd Posted December 30, 2004 Report Share Posted December 30, 2004 er... aren't the whole steering columns different?You are correct, sir!!! Quote Link to comment Share on other sites More sharing options...
stockgp Posted January 3, 2005 Author Report Share Posted January 3, 2005 ok. but you're not answering the second half of my question. the 93ish switches, from what i can tell are 4-wire. the 97 switch seems to only have 3 wires. how does each control the high beams and how would i make a 97 switch work with a 93 headlight system Quote Link to comment Share on other sites More sharing options...
wilde108 Posted January 3, 2005 Report Share Posted January 3, 2005 I have been having an issue with my highbeams. They simply don't work. I can't even pull the switch back. Nothing clicks. But if the car is off and the key is half turned the highbeams will work but the "click" in the switch is not there. I hope someone understands my rambling. Quote Link to comment Share on other sites More sharing options...
DiscoStudd Posted January 3, 2005 Report Share Posted January 3, 2005 I have been having an issue with my highbeams. They simply don't work. I can't even pull the switch back. Nothing clicks. But if the car is off and the key is half turned the highbeams will work but the "click" in the switch is not there. I hope someone understands my rambling.What year is your car? Quote Link to comment Share on other sites More sharing options...
