recommend silicone spray?
Does anyone use or know of a good quality spray to pu ton the weather stripping around the doors to prevent the door and stripping from freeing together and will last a lil while? or at least aid in preventing alot of it?
Wd-40 doesnt work for long at all and I don't want to break the handles in this weather.
Thanks in advance Fargo:
I've heard of people using petroleum jelly I guess. You in Fargo ND? I'm up in Grand Forks.
naw im in niagara Falls, Ontario
petro jelly hmm, that would be a good excuse to buy for my doors lmao
Silicone grease is what GM recommends. I never did like the spray, it never lasted long enough. The grease lasts much longer. Petroleum jelly should work in winter, but it liquifies in hot weather.
I just used a big tube of Permatex Di-electric grease. It works wonderfully to stop leaks on the convertible for LOOOONG periods of time.
Silicone attracts too much dirt and grime. You can get this stuff called 303 Protectant at Ace hardware (in the automotive aisle).
Much better than silicone, IMO.
