my reverse lights
stlunatics2oo3
yeah i have an 89 cutlass supreme and i have changed bulbs in my reverse lights and stuff and they are not workin at all and i am just stumped in any one has an i dea it would be greatly appreciated
thanks
Next place to look - Fuse.
After that, you should check the switch. I believe it's mounted on the tranny. I would have to look up the exact location.
If it's the tranny mounted switch, that's kind of tricky to get to. I think it's easier to access by removing the airbox. Sometimes it just goes out of adjustment. It has an elongated hole so if you loosen both screws, it can be pivoted. It could just be out of adjustment, or need replacing. I've actually taken mine apart and cleaned/repaired some broken contacts with some solder (my trunk release was not working).
well thanks i will have to look at it soon so how much do these switches cost if any one knows by chance
IIRC, the exhaust is near there. You might want to make sure the engine is cold befor you go poking there... :devil:
