CuttySup Posted December 27, 2004 Report Posted December 27, 2004 So last night, I was driving down the expressway, I go to exit, and as I'm pulling up to the stop sign at the end of the ramp, my "door ajar" chime starts going off. I've never heard of this happening, and I didn't know how to stop it. I ended up pulling over and shutting the car off and restarting it and it shut off and works fine. The ABS light had been on for the duration of the 30 min. trip. I don't know if that has anything to do with it. Any ideas? Quote
DiscoStudd Posted December 27, 2004 Report Posted December 27, 2004 Was your turn signal on at the time? If so, it was most likely the "Turn Signal Reminder Chime" letting you know you've left your signal on too long. I think it goes off if you've been driving above a certain speed for over a minute with the signal on... You mention the ABS light being on. You might want to check the tightness of the nut on your Auxillary Positive Terminal (use a 15mm deep-well socket, and be careful not to hit the end of the ratched on anything metal...) Quote
CuttySup Posted December 28, 2004 Author Report Posted December 28, 2004 Was your turn signal on at the time? If so, it was most likely the "Turn Signal Reminder Chime" letting you know you've left your signal on too long. I think it goes off if you've been driving above a certain speed for over a minute with the signal on... You mention the ABS light being on. You might want to check the tightness of the nut on your Auxillary Positive Terminal (use a 15mm deep-well socket, and be careful not to hit the end of the ratched on anything metal...) That's so gay! Know that I think of it, my turn signal was on for the length of the ramp. I have an electronic flasher which makes the tick that the turn signals make a lot quieter. When I merged from the highway to the decceleration lane I had my right turn signal on, and forgot to turn it off once I completed the manuver. So it was on a whole TEN SECONDS Quote
White93z34 Posted December 28, 2004 Report Posted December 28, 2004 i think the alarm comes on after a 1/4 mile, but i have no way of verifying that since mine is disabled. Quote
digitaloutsider Posted December 28, 2004 Report Posted December 28, 2004 My car doesn't have this mysterious turn signal chime. Quote
CuttySup Posted December 28, 2004 Author Report Posted December 28, 2004 i think the alarm comes on after a 1/4 mile, but i have no way of verifying that since mine is disabled.That would explain it then, thanks. Quote
EurosportZ34 Posted December 28, 2004 Report Posted December 28, 2004 My car doesn't have this mysterious turn signal chime. mine neither...must be on the "newer" Ws Quote
jeremy Posted December 28, 2004 Report Posted December 28, 2004 mine neither...must be on the "newer" Ws mine does it, but I had no idea it did until I read about it on here then turned my signal on and drove for a 1/4 mile like a moron....sure enough it went *ding* *ding* Quote
CuttySup Posted December 29, 2004 Author Report Posted December 29, 2004 mine neither...must be on the "newer" Ws mine does it, but I had no idea it did until I read about it on here then turned my signal on and drove for a 1/4 mile like a moron....sure enough it went *ding* *ding* Me too! Quote
93CutlassSupreme Posted December 29, 2004 Report Posted December 29, 2004 my Cutlass had it... newer GM's don't have a chime, a "Turn Sgnl" message comes up on the DIC Quote
