toastemcutlass Posted January 12, 2003 Report Share Posted January 12, 2003 Did the cutlass's come with the dic in 94? if not is their a wiring harness there? Quote Link to comment Share on other sites More sharing options...
Brian P Posted January 12, 2003 Report Share Posted January 12, 2003 never came with it but it can be installed if you have the 3.4 (old PCM) Quote Link to comment Share on other sites More sharing options...
toastemcutlass Posted January 12, 2003 Author Report Share Posted January 12, 2003 how old is the old pcm, before the maf sensor? cus I have the maf sensor Quote Link to comment Share on other sites More sharing options...
Brian P Posted January 12, 2003 Report Share Posted January 12, 2003 I mean in '94 the 3100 got the OBD2ish (like 1.5 really) PCM that may or may not have all the data that the DIC needs. The 3.4dohc in '94 kept the same PCM that was used in 91+ so it definetly has all the data. Shawn tested one out in his 94 vert and it worked Quote Link to comment Share on other sites More sharing options...
GnatGoSplat Posted January 12, 2003 Report Share Posted January 12, 2003 Yep, the DIC will work in your 94 since you have the 3.4 DOHC! I don't think the harness is there, but I didn't pull the climate control to check for sure, although I DID fish around with my hands and didn't find anything. Mine has MAF, SFI, etc. also, but the DIC still works. I connected a DIC out of an 89 and it worked great! I didn't hardwire it, just plugged it into the ALDL connector, but it picked up all the functions under the "gages" button (coolant temp, volts, rpm, etc.). I plan to permanently install one into my '94, but right now I still have to finish my HUD project in the '89. Quote Link to comment Share on other sites More sharing options...
toastemcutlass Posted January 12, 2003 Author Report Share Posted January 12, 2003 hell ya now all i need is the unit :? also am working on the hud which seems pretty tight. Quote Link to comment Share on other sites More sharing options...
GnatGoSplat Posted January 12, 2003 Report Share Posted January 12, 2003 Email this guy: TeamPontiac88@aol.com He had 2 of them for $20 shipped each. Quote Link to comment Share on other sites More sharing options...
