Stealth Posted December 24, 2004 Report Posted December 24, 2004 the drivers seat seems to be coming loose how do I tightin it? the rubber strip on the inside of the window keeps folding when you put the window down, latelty its been jamming and strainng the motor what can I do? Quote
Dannymik Posted December 24, 2004 Report Posted December 24, 2004 as for the drivers seat, there are 4 main bolts that hold it down(I dont remember the socket size)...you'll see them at each end of the tracks...just tighten them down. Quote
GP1138 Posted December 24, 2004 Report Posted December 24, 2004 the drivers seat seems to be coming loose how do I tightin it? the rubber strip on the inside of the window keeps folding when you put the window down, latelty its been jamming and strainng the motor what can I do? A: The drivers seats are held in place by reverse torx bolts, I believe. You can tighten them with a normal socket or something, I can't remember the size. B: The rubber strip you speak of might be able to bend outwards a little, try that, try to make a little bit of a crease, to make it stay. Otherwise you might just have to live with it. Quote
Dannymik Posted December 24, 2004 Report Posted December 24, 2004 8mm speaking of the 8mm...I broke mine last time I was tightening down my drivers side seat in my Cutlass ...thanks to a Craftsman guarantee Quote
sonyman87 Posted December 24, 2004 Report Posted December 24, 2004 Put some petrolium jelly or Armoral on the rubber seal. it should slicken it up some. Quote
