sonyman87 Posted December 22, 2004 Report Posted December 22, 2004 my car is so going to die soon. i have covered most of my driveway with oil spots from parking in different places. i dont know where the oil is exacly comeing form but its pretty much the backhalf of the motor by the firewall. cant tell which side either b/c its running threw the cradel fram holes and spreds out equialy to both sides. this car suppose to last me until atleast this summer so i get get new trackslips and a new car or atleast a motor swap. Quote
WhiteOut Posted December 23, 2004 Report Posted December 23, 2004 Mine has the exact same problem. My o-ring leak was fixed and I've taken it apart since then and its still dry as a bone. I've also replaced my valve cover gaskets since they leaked, but I'm still leaving oil spots en masse. I know mine is oil because I go through a quart every third week or so. Quote
5speedz34 Posted December 23, 2004 Report Posted December 23, 2004 I doubt it, but maybe a freeze plug? Quote
93GTP Posted December 23, 2004 Report Posted December 23, 2004 When I tore down my engine to fix a suspected distributor o-ring leak, I discovered that it wasn't the o-ring at all. It was actually the cylinder head gasket that had failed on the front cylinder bank. It was leaking at the oil passage from the block to the cylinder head/cam carrier. Oil was collecting in the valley between the cylinders and running in many places, but mostly down over the transmission on both front and back sides. Quote
sonyman87 Posted December 24, 2004 Author Report Posted December 24, 2004 well i am missing Zero oil and its been leaking for over a month. I think it actualy is my PS fluid. i added some mild clear ps fluid and picked up a few drops of clear oil so i think it really is my PS line somewhere backthere. Plus I keep loosing coolant.. also gradual. car still runs stronger then the day i got it. I'm in no mood to mess with it this holiday season so i will either leak until january or drop it off somewhere. Quote
cutlsp Posted December 24, 2004 Report Posted December 24, 2004 you could add a little lucas power steering fluid stuff see if it stops the leaks its worth a shot :? Quote
Robby1870 Posted December 24, 2004 Report Posted December 24, 2004 My STE has a small P/S fluid leak, but I just keep dumping more in, about a bottle very 3000. Im not going to fix it any time soon, I cant even see where its leaking from. Leaks a touch of coolant too, but its from a bad spot in a line that I dont want to fix. If its not oil, tranny fluid or brake fluid, dont worry too much, LOL Quote
sonyman87 Posted December 24, 2004 Author Report Posted December 24, 2004 My STE has a small P/S fluid leak, but I just keep dumping more in, about a bottle very 3000. Im not going to fix it any time soon, I cant even see where its leaking from. Leaks a touch of coolant too, but its from a bad spot in a line that I dont want to fix. If its not oil, tranny fluid or brake fluid, dont worry too much, LOL worry to much lol. i was thinking my car was going to blowup anysecond when i was driving.. thinking that leak its going to give way and the oil is going to spew out allover the road and all hell is going to break loose. thats befor i found out it was PS fluid. Now i worry about the line giving way and not being able to stear when im doing highway speeds. im sure it will be fine for now i just cant let it stay like that for long Quote
WhiteOut Posted December 24, 2004 Report Posted December 24, 2004 I doubt it, but maybe a freeze plug? Freeze plugs only leak coolant. I'm more worried that its a cylinder head gasket. I guess the best case scenario at this point is a cam carrier to head gasket. Quote
5speedz34 Posted December 24, 2004 Report Posted December 24, 2004 5speedz34 wrote:I doubt it, but maybe a freeze plug? Freeze plugs only leak coolant. I'm more worried that its a cylinder head gasket. I guess the best case scenario at this point is a cam carrier to head gasket. Ohh, I feel stupid. :oops: robby1870 wrote:My STE has a small P/S fluid leak, but I just keep dumping more in, about a bottle very 3000. Im not going to fix it any time soon, I cant even see where its leaking from. Leaks a touch of coolant too, but its from a bad spot in a line that I dont want to fix. If its not oil, tranny fluid or brake fluid, dont worry too much, LOL worry to much lol. i was thinking my car was going to blowup anysecond when i was driving.. thinking that leak its going to give way and the oil is going to spew out allover the road and all hell is going to break loose. thats befor i found out it was PS fluid. Now i worry about the line giving way and not being able to stear when im doing highway speeds. im sure it will be fine for now i just cant let it stay like that for long I'm just like that too, if something is leaking the most very little, I get all bent out of shape, and afraid who knows WTF is going to happen, Quote
