GM Fuel Pump for 97-2003 SC engines (Vin1)
I'm trying to find out if it's possible to swap original fuel pump on a 2001 Regal GS with a supercharged engine for a performance in tank fuel pump. I really do not wish to pay 300+ bucks for the entire assembly when only the pump has failed.
My concerns are: the pressure and the volume that the fuel pump will provide.
The original pump produces 48-55 PSI. Does any one know the volume of fuel it will do?
I was looking at some highvolume Edelbrock pumps (255 liter/hr. (67 gph), 60+ psi for Turbo, Supercharger or Nitrous). Would this work ok in my case?
Any help would be appreciated.
Jack
are you looking for performance increases from this "better pump" because you FPR will keep it at the pressure it is designed for
I know that.
The real reason is to get a pump for cheaper. I'm looking right now at spending over $300 +S/H
Most performance Fuel Pumps cost less than $150.
I have a custom fuel pump assembly and do not want to void the OEM warranty by removing the pump from the Assembly.
The OEM pump failed, since I removed it from the assembly, they won't take it back. That's the deal :(
are you the guy that put the regal interior into a lumina? if so, great work.
anywho, check out http://www.l67swap.com . i know it was posted on there at one time the gph and what not that the fuel pump will do. and if i'm not mistaken they recomended a holley fuel pump for the guys doing an l67 swap, so there is an aftermarket pump out there
Intense Racing sells the Walbro 255 liter/hr fuel pump that everyone on L67Swap.com talks about.
Here's the link:
http://www.intense-racing.com/Merchant2/merchant.mvc?Screen=PROD&Product_Code=WFP-169&Category_Code=IF
I would not buy that one if I was you. There is a huge thread about that pump on clubgp not performing like its supposed to.
http://www.clubgp.com/newforum/tm.asp?m=1878071&p=1&tmode=1&smode=1
How long do you think this pump would last. Is it one of those good for a couple of races products or something that would last for years?
By the way, thanks a lot. exactly what I was looking for. :wink:
