Speckkial Posted December 15, 2004 Report Posted December 15, 2004 I need a replacement knob inside my car. I found this on the internet: http://www.expressautoparts.com/store/index.cfm?do=list&logcategory=ACSWAMS What do they mean by this: 15-75090 [Heater & AC Control Knob] w/Amber LED; w/Opt. CJ2; Aux Temp Lever Control Quote
jeremy Posted December 15, 2004 Report Posted December 15, 2004 that link just takes you to their main page... Quote
Speckkial Posted December 15, 2004 Author Report Posted December 15, 2004 Well this is what it says: Click on the add to cart icon to add an item to your shopping cart. Search Results: 1996 OLDSMOBILE CUTLASS SUPREME : Different Car? A/C SWITCHES: SWITCH, A/C & HEATER CONTROL Replacement Accessories Performance Brand / Part No. Description List Your Price Unit QTY Buy Estimated Ground Shipping Time: 2-5 days (based on your proximity to our warehouse network) * AC DELCO 15-72143 [Heater & AC Control] w/Elect. AC; C67; Exc. Aux. Temp.; CJ2 $298.68 $210.75 each 15-72207 [Heater & AC Control] w/Aux. Temp. CJ2 $537.62 $379.35 each 15-75076 [Heater & AC Control Knob] Control Select $9.77 $6.89 each 15-75090 [Heater & AC Control Knob] w/Amber LED; w/Opt. CJ2; Aux Temp Lever Control $12.73 $8.99 each Quote
jeremy Posted December 15, 2004 Report Posted December 15, 2004 there are two types of knobs depending on which HVAC system you have...here is a pic of mine, notice how the knobs are different then they standard control......on a side note, why don't you just go to a yard a pull one? Quote
Speckkial Posted December 15, 2004 Author Report Posted December 15, 2004 I have the regular three knobs in a row. What year is your car? Quote
jeremy Posted December 15, 2004 Report Posted December 15, 2004 I have the regular three knobs in a row. What year is your car? '97 but the dual zone was available from '95-97... Quote
DiscoStudd Posted December 15, 2004 Report Posted December 15, 2004 Good luck finding those knobs in the yard. They're notorious for breaking. I went in search of knobs for my GP (which is the same unit that's in the Cutty's, 'cept the knobs are gray) and the only knobs I found were already broken. I found a knob off of a 95-01 Lumina and got it to work by taking a dremel and cutting off the "lip" and the "stops" on the back side so it would sit flush and turn all the way around. I had to put a drop of superglue on the end of the shaft so it would stay on better, otherwise it works perfectly. Huh huh huh, you said "shaft!" Huh huh huh... Quote
93CutlassSupreme Posted December 17, 2004 Report Posted December 17, 2004 Good luck finding those knobs in the yard. They're notorious for breaking. I went in search of knobs for my GP (which is the same unit that's in the Cutty's, 'cept the knobs are gray) and the only knobs I found were already broken. I found a knob off of a 95-01 Lumina and got it to work by taking a dremel and cutting off the "lip" and the "stops" on the back side so it would sit flush and turn all the way around. I had to put a drop of superglue on the end of the shaft so it would stay on better, otherwise it works perfectly. Huh huh huh, you said "shaft!" Huh huh huh... Yeah yeah, you said "knobs" too! Quote
5speedz34 Posted December 17, 2004 Report Posted December 17, 2004 Jeremy, the DIC looks great in your car! Were is your radio though? Quote
jeremy Posted December 17, 2004 Report Posted December 17, 2004 Jeremy, the DIC looks great in your car! Were is your radio though? under the passenger seat....when I stop being lazy, I will put it in the center console Quote
