Hey I've seen the wright up on this but wanted to know if anyone has done it and is it as easy as it sounds... :?:
I've never done it but it can't be much difficult than changing the struts and brakes out.
I've done it and it is as easy as it sounds. I believe I have a post on here about it. I know I have some pics on my cardomain. You will need a 1/2" breaker bar + some very large metric and standard sockets. The brake line fittings will probably strip if you try to use an actual pipe wrench- a 4" vise grip is perfect here. Good luck!
Tim
sweet.. i found some off of someones 99 z34 that had been wrecked out im going to get them, How much better does it stop compaired to the junky ass drums
IMO, it's 100% better. Check your brake booster hose while you're at it. It will also greatly affect braking.
Tim
