quinn Posted December 12, 2004 Report Posted December 12, 2004 I just got a elect. flasher yesterday for my '92 gp. All signals don't work, but cruise and hi-beams do. I just took off the "under dash" panel and was looking for the flasher so I could replace it. Well, I can't see any canister or any hint of a flasher. Could someone point me in the right direction? Is it ON the firewall? ON the column? I was looking where I thought it would be, but there's just a vent hose. If anyone can help, thanks. Quote
supreme_style21 Posted December 12, 2004 Report Posted December 12, 2004 It is not on either.. but it will be just to the right of the steering column... almost to the firewall. IIRC, it'll be to the left of the arm for the brake pedal. Quote
CuttySup Posted December 12, 2004 Report Posted December 12, 2004 It would be easier if the signals worked, then you could just listen and feel around. It was a little difficult for me to mind it. Just look for a silver cylinder a little smaller than your electronic flasher. On the Cutlasses, it is a little out of the way. It's up there though, just have to look a little. It's a bitch to get off. You have to wiggle it around a lot, or use a knife or a flathead screwdriver to pry the plug off. Quote
DiscoStudd Posted December 12, 2004 Report Posted December 12, 2004 Here's the location: This pic is the location of the main signal flasher. The hazzard flasher (on the 94-96's) is located right under the headlight switch. Quote
quinn Posted December 12, 2004 Author Report Posted December 12, 2004 thanks disco, found it, replaced it, everything works. Quote
DiscoStudd Posted December 13, 2004 Report Posted December 13, 2004 thanks disco, found it, replaced it, everything works. Sweet! Glad I could be of assistance... Quote
digitaloutsider Posted December 13, 2004 Report Posted December 13, 2004 Glad I could be of assistance too. Quote
