ok so i put my engine back in and when i go to put fluid in it starts to leak out from around the pass half shaft i really cant see. anyways will it leak out if the car is not on or if it is full or will is it just a nother problem
sounds like a problem to me...it won't leak out just because the car isnt on...and i don't think its gonna leak out there if it is overfilled either...sounds like a seal to me...
it was just rebuilt. do you think i might have put the half shaft not all the way in
make sure your final drive case isn't broken. Basically the end of the tranny case, RHS, is removeable. Either it's not tight, no seal, or broken. Just a lookout.
