BimmerJr87 Posted December 9, 2004 Report Posted December 9, 2004 Alright guys im gonna get my car tuned up what stuff do I need, I know im gonna get the AC Delco rapid fires but what else do I need? Quote
BimmerJr87 Posted December 9, 2004 Author Report Posted December 9, 2004 should i get any of the wires changed for the spark plugs? Quote
terryk2003 Posted December 9, 2004 Report Posted December 9, 2004 if you're tuning it up, i'd deffinatly get plug wires also...and i'd also recommend a fuel filter...and check the air filter...if it looks bad, replace it... Quote
EurosportZ34 Posted December 9, 2004 Report Posted December 9, 2004 Magnecor 8.5mm KV85's for the 3.4 DOHC work wonders Quote
WhiteOut Posted December 9, 2004 Report Posted December 9, 2004 How much do you want to spend? Bare essentials: Plugs, air filter, fuel filter, TB cleansing, PCV valve, oil change. Extras: Wire set, coolant flush/fill, transmission fluid flush/fill, transmission filter. I'm sure others can add to the list. The basics will probably run you around $50-60. The whole shebang probably around $225-250 if you do the work yourself. Quote
