Cutlass Posted December 6, 2004 Report Share Posted December 6, 2004 I just picked up a 99 Intrigue with 67k miles. Great car, the only problem I'm seeing is that the air coming out of the vents isn't very powerful. I had an Eighty-Eight with the same problem and the mechanic fixed it by flushing out the evaporator. I'd like to do it myself this time, but I really don't know the procedure. Can anyone help? Thanks. Quote Link to comment Share on other sites More sharing options...
mfewtrail Posted December 6, 2004 Report Share Posted December 6, 2004 Here's a generic guide that shows what you're wanting to do. http://www.diynet.com/diy/ab_auto_air_conditioning/article/0,2021,DIY_13674_2276709,00.html Quote Link to comment Share on other sites More sharing options...
paulo57509 Posted December 6, 2004 Report Share Posted December 6, 2004 I just picked up a 99 Intrigue with 67k miles. Great car, the only problem I'm seeing is that the air coming out of the vents isn't very powerful. I had an Eighty-Eight with the same problem and the mechanic fixed it by flushing out the evaporator. I'd like to do it myself this time, but I really don't know the procedure. Can anyone help? Thanks. It's not clear to me what you mean by "air coming out of the vents isn't very powerful..." Do you mean the air isn't cold or the air isn't coming out fast enough? By "flushing" do you mean cleaning the outside of the evaporator of dirt and debris or actually flushing the inside of the evaporator? If you're flushing the inside of the evaporator, you have a much more serious problem. The inside of the evaporator shouldn't clog unless the compressor blew its guts (black death). :shock: http://www.ackits.com/forum/messageview.cfm?catid=20&threadid=9178 Go here and spend an hour or so reading the posts. The "Tips and FAQ are most helpful: http://www.ackits.com/forum/ Quote Link to comment Share on other sites More sharing options...
GPdriver1986 Posted December 6, 2004 Report Share Posted December 6, 2004 I think he means that the evap is plugged up on the outside and it needs to be cleaned, all you have to do is get to it by taking apart some of the interior. Another thing is you can do is take some brake cleaner and use that to degrease it and bring out all the stubborn dirt. Then take some compressed air and dry it out. If you think this is too complicated you can a hose and just spray in the vent on the windshield cowl where the car takes in air for the interior. You should also check to see if ur vacum is working. Quote Link to comment Share on other sites More sharing options...
Cutlass Posted December 8, 2004 Author Report Share Posted December 8, 2004 Thanks for the insight. I'm picking the car up on Saturday morning, so I haven't had a chance to take it apart yet. I'm also thinking it could be a clogged pollen filter. Quote Link to comment Share on other sites More sharing options...
