cutlassconvertible Posted December 5, 2004 Report Share Posted December 5, 2004 Hey whats up all? i was wondeirng about adding a HUD to an 01 GP. do u know which parts i would need. ok i know that i would need the actual HUD unit, the HUD switch/controls, and the dash panel with the cutout for the display. but do we know if there are any other parts i would need to track down??? thanx Quote Link to comment Share on other sites More sharing options...
White93z34 Posted December 5, 2004 Report Share Posted December 5, 2004 as you said you will need the HUD itself, the switch and the dash pad. over on http://www.clubgp.com they have a prety good write up on how to install it, just be damn sure that your gona sell the car with the HUD since after you put in you can't take it back out. Quote Link to comment Share on other sites More sharing options...
Crimson Fury Z Posted December 5, 2004 Report Share Posted December 5, 2004 the, main thing is splicing hud's wires to the matching wires on the dash cluster's. you can splice it to be removable w/the right wire connectors, if so, save the original dash pad Quote Link to comment Share on other sites More sharing options...
no1kicker Posted December 5, 2004 Report Share Posted December 5, 2004 So the gen2's aren't prewired? And why couldn't you take the HUD out? I would guess that you could just remove the harness and make sure no actual wire was out. :?: Quote Link to comment Share on other sites More sharing options...
White93z34 Posted December 6, 2004 Report Share Posted December 6, 2004 most gen2 GPs are prewired, all you gotta do is grab the harnas for th hud that is aorund the speedometer and reach backup in the dash behind the cubby for the harnas for the switch Quote Link to comment Share on other sites More sharing options...
