Guest Gp crazy Posted December 5, 2004 Report Posted December 5, 2004 I was driving around & noticed water on floor of my GP STE 1/2 an inch DEEP So I was wondering if sunroof has a drain pipe some WHERE! IM not sure where it is! Also I looking for a driver seat for the same car it's a 1990 STE gray in color, adjustable. Must have good frame. mine leans to the left to much and the back is falling out of it thanks jeff 13069 If any body has a seat this is the zip it will be sent to $ + shipping please! thanks Quote
93CutlassSupreme Posted December 5, 2004 Report Posted December 5, 2004 the sunroof does have drains, two if i'm correct. it's been a while since i've looked at mine, i can't remember exactly where they go. Quote
Guest Anonymous Posted December 5, 2004 Report Posted December 5, 2004 The drain hoses go down inside the pillars. Quote
Regal_GS_1989 Posted December 5, 2004 Report Posted December 5, 2004 Yea, The sunroof has two that go down through the pillars, the water flows out from under the door. But i' don't know if it would be the sunroof. Hell, 1/2 an inch is a lot of water. You sure that it isn't leaking from somewhere else. Windshield seal, weather stripping...etc. Quote
DiscoStudd Posted December 5, 2004 Report Posted December 5, 2004 The evaporator drain may also be plugged, allowing water to overflow onto the floor... Quote
Guest Gp crazy Posted December 7, 2004 Report Posted December 7, 2004 thanks i will be looking for both spots overflow can for evap. and look in to drain tubes in the pillars. Quote
Crimson Fury Z Posted December 8, 2004 Report Posted December 8, 2004 water on the floor sucks big, but leaks weren't the cause of that when i had my elec roof fixed, 1 of the drain panel things were broke! but yeah, listen to them and check those 2 things Quote
