DIC and seats ?
crazychuck29
at the junkyard i found an 88 or 89 se not sure on the year....anyways it had the DIC and it had the seats that look like the TGP seats i wasn't sure if they put them in the regular GP's anyways i was wonderin if the seats would fit no problem and the wiring....also with the console how hard would it be to make it from a collum shifter to a floor shifter...plus could i wire up the DIC to my lumi...thanks.......
shifter is easy, you replace the cable, and run your other cable up to the ign switch for the neutral safety and stuff. only problem is the columns are a little different.
i did my buddy's 93 euro with parts off my cutlass.
